asa5510 no site to site with watchguard
error message
Apr 02 18:52:19 [IKEv1]: Group = 219.240.18.2, IP = 219.240.18.2, Removing peer from peer table failed, no match!
Apr 02 18:52:19 [IKEv1]: Group = 219.240.18.2, IP = 219.240.18.2, Error: Unable to remove PeerTblEntry
1 REPLY
Bronze
Re: asa5510 no site to site with watchguard
It is quite impossible to help you when you're not giving a lot of information. I can point you in the right direction according to the error message, but it would be better if your post some more information te next time you have a problem.
You can find a step-by-step instruction for configurating a VPN Tunnel between a ASA and a Checkpoint Firewall. The configuration is almost the same for a ASA to a Watchguard!
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008009420f.shtml
Configuration Guides for the ASA can be found here:
http://www.cisco.com/en/US/products/ps6120/products_installation_and_configuration_guides_list.html
Loads of configuration examples for the ASA can be found here:
http://www.cisco.com/en/US/products/ps6120/prod_configuration_examples_list.html
Hope this information can help you solve your problem, it is very important to check your configuration twice for configuration-problems !
Please rate if the post helps!
Michael
340
