ASA5520 - Deployment questions
Hi!
I'm deploying a 2 ASA5520 solution and i have the folowing questions:
- since i'm deploying these ASAs in a single customer network do i have any advantages using multiple context insted of single context configuration?
- with a single context topology i only can deploy an Active/Standby failover solution?
- hows does the A/S failover work with VPN load balancing feature?
JP
1 REPLY
Bronze
Re: ASA5520 - Deployment questions
This document describes how to install and configure the Cisco ASA 5510, 5520, and 5540 adaptive security appliance to be used in VPN, DMZ, remote-access, and intrusion protection deployments.
When you have completed the procedures outlined in this document, the adaptive security appliance will be running a robust VPN, DMZ, or remote-access configuration appropriate for most deployments. The document provides only enough information to get the adaptive security appliance up and running with a basic configuration.
http://www.cisco.com/en/US/products/ps6120/products_quick_start09186a00803eaf00.html
153
