Community Member
ASA5520 question: Vlan?
I have ASA5520, and I want create three vlans for:
inside: a database network
ouside: my company
DMZ: a content delivery network.
I found I can not use vlan
#conf t
(config)#int Vlan 123
ERROR: % Invalid input detected at '^' markers.
Since we use cisco catalyst switch, I would like to use vlan, not ip address on a interface.
is ASA5520 can use vlan? or is I have license issure again?
Any comments will be appreciated
Thanks in advance
1 REPLY
Re: ASA5520 question: Vlan?
Please check below:
hostname(config)# interface gigabitethernet0/1.100
Step 2 To specify the VLAN for the subinterface, enter the following command:
hostname(config-subif)# vlan vlan_id
The vlan_id is an integer between 1 and 4094.
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a0080450b7d.html#wp1044006
Hope it helps.
Franco Zamora
105
