Community Member
ASA5520 redundant ISP on virtual interfaces
Is it possible to implement redundant ISP's with failover firewalls using virtual interfaces and the ISP connetions? I have a 5520 with the standard number of interfaces and want to create virtual interfaces on the outisde interface?
Community Member
Re: ASA5520 redundant ISP on virtual interfaces
When you say virtual interfaces are you talking about sub interfaces?
These can each be a different vlan and can be monitored for failover etc...
Community Member
You may create a sub-interface on the outside interface and use it as a backup interface. Here is a sample config :
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_7_2/conf_gd/ref/examples.htm#wp1038632
Please rate if it helps.
Sincerely,
~AJ
Silver
The interface tracking in that version brakes when using a failover pair. The tracking works until failover occurs. Then a reboot of both firewalls is required to fix the tracking.
Bug: CSCsd51407
Dual ISP fails after failover, routing table have stale routes
A new release is coming soon to fix the bug. 7.2(1) is the only version out that supports tracking.
Chad
Community Member
looks like they fixed the bug in ver 7.2.1.24 on the 10/30/2006
bug id CSCse99033
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCse99033&Submit=Search
269
