Running an ASA5520 7.0(1)that will periodically "reset". All VPN traffic then gets cut off until we manually re-enter the DNS info that was "saved" to flash. Ideas? Thanks.
Our internal DNS -- we simply relay internally to the "real" world. The LAN access of course, does not work without the DNS info in the ASA. There are really two questions here: why the spontaneous reset, and why does saved DNS info not save?
Via ASDM, under the VPN tab, General tab, Group Policy definition, is a default group policy that contains the primary and secondary DNS IP addresses. Yes, it says it has saved it to flash, but the spontaneous reboot clears this one setting.
BenefitsDocumentationPrerequisiteImage Download LinksLimitationsSupported PlatformsLicense RequirementsTopologyStep-By-Step ConfigurationConfigure Virtual ServiceActivate the virtual service and configure guest IPsConfiguring UTD (Service Plane)Configurin...
view more
Login to the FXOS chassis manager.
Direct your browser to https://hostname/, and log-in using the user-name and password.
Go to Help > About and check the current version:
Check the current version availa...
view more
We have configured the outside and inside Interface with official ipv6 adresses, set a default route on outside Interface to our router, we also have definied a rule , which also gets hits, to permit tcp from inside Interface to any6.
In Syslog I also se...
view more
