Community Member
ASDM 5.0.5 not loaded with ASA 7.0.5
A have an ASA5520, which was running with the image: asa704-4-k8.bin and the ADSM: asdm504-2.bin
I upgraded the image in 7.0.5, and the ADSM in 5.0.5
The ASA boots correctly with this new version 7.0.5, but still boot with the ADSM asdm504-2.bin and not the asdm505.bin
In the configuration, I have the next boot variable:
boot system disk0:/asa705-k8.bin
boot system disk0:/asdm505.bin
So, I'd like to know why the ASA 5520 doesn't accept the ADSM file at boot.
P.S: the ADSM file size in the flash is: 5823304
1 REPLY
Re: ASDM 5.0.5 not loaded with ASA 7.0.5
Can you check how many asdm image you have in your flash? Use sh flash or dir command.
You can also specify the asdm image to be used using "pixfirewall(config)#asdm image flash:asdm-501.bin" command
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804708d8.shtml#t8
Rgds,
AK
133
