ASDM 5.1(2) Hangs at 20% on Load
In the middle of configuring a fresh pix 515e with cli 7.1(2) and asdm 5.1(2). ASDM loaded up just fine saved a couple of changes and reloaded a couple of times. Had 3 interfaces enabled and and some static routes from outside to dmz1 with access-lists.
After reload asdm application on the desktop freezes when loading at 20%. Tried to load java applette instead from https but that freezes too at 89%.
Tried to rebuild config with 'configure factory-default 192.168.1.1' Still no luck. Switched unit off couple of times and let it boot with clean configuration from factory default with https enabled and all still no luck.
ASDM hangs at 20% and says 'Loading cached software'
Any thoughts?
Re: ASDM 5.1(2) Hangs at 20% on Load
How about your JRE?
Cheer,
Nitass
Thanks for that...went to another system and ASDM works fine.
366
