Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
ASDM Dashboard Customization
We use the ASDM with our Firewall Service Modules and ASA's to monitor their status via the supplied Dashboards. On the FWSM - especially - we have many interfaces, but it seems the ASDM dashboard picks the interface in the middle of the pack to display stats in the Traffic Status section.
Is there a way to force this to view another interface? I do not see an INI file or other editable to cause this to happen.
Re: ASDM Dashboard Customization
Did you ever find a way to do this?
Nope, never did.  There is no way to select what interface is graphed.  I did notice that when you switch between contexts in a multi context environment, it will select an interface within that context.
1171
