Community Member
ASDM launch on ASA outside interface
I want to launch ASDM on ASA outside interface having private IP from locan LAN. This server farm asa is connected with core switch.From Core switch i can ping the asa outside ip (192.168.10.2/30). In ASA i did the following:
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.10.0 255.255.255.252 outside
telnet 192.168.10.0 255.255.255.0 outside
Please help..
1 REPLY
Re: ASDM launch on ASA outside interface
what subnet are you seating on for the outside? seems as you are comming from the outside as 192.168.10.0/24 network, if so you you need to add another statement for asdm access via outside interface.
add this and try launching asdm from this subnet to access fw.
asa(config)#http 192.168.10.0 255.255.255.0 oustide
Rgds
Jorge
291
