Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Assigning Static Routes from ACS to 3620 for branch office connectivity
I am attempting to configure the above components in order that the Cisco's Routing table is updated with the appropriate static route once the remote router is authenticated using the Cisco ACS v3 RADIUS server.
The connection seems to authenticate fine, but the static route does not seem to be applied to the routing table. Only the host IP address of the remote router is shown in the table (during BACP neg.).
I've used Framed-Route, Service-Type & Framed-Protocol for the RADIUS attributes. Can you tell me whether there should be anything to watch out for in the 3620 config? Should I use the cisco-avpair attribute?
Thanks in advance.
Matt
1 REPLY
Re: Assigning Static Routes from ACS to 3620 for branch office c
121
