ATM interface doesn't come up
I'm installing a Cisco827 on an ADSL link. Now ther is a Netopia4541 connected, but we want to swap that with the Cisco827.
If contacted my ISP and they said that if I configure following statements it should work.
Protocol PPPoA
Modulatie G.DMT
Encapsulatie VC Mux
VPI 0
VCI 35
Gebruikersnaam systeemnaam@demon.nl
Password SDU wachtwoord
I made the changes and my config is as follows:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname VPN_CRS-01
enable password xxxxx
username xxxxxx password xxxxxx
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
crypto isakmp policy 10
hash md5
authentication pre-share
group 2
crypto isakmp key test address 80.xx.xx.xxx
crypto ipsec transform-set media esp-des esp-md5-hmac
crypto map ciris 10 ipsec-isakmp
set peer 80.xx.xx.xxx
set transform-set media
match address 100
interface Ethernet0
ip address 10.1.0.1 255.255.0.0
hold-queue 100 out
interface ATM0
ip address 212.zzz.zzz.zzz 255.255.255.240
no atm ilmi-keepalive
pvc 0/35
encapsulation aal5mux ppp dialer
dsl operating-mode auto
ip classless
ip http server
ip pim bidir-enable
access-list 100 permit ip 10.1.0.0 0.0.255.255 172.48.0.0 0.0.255.255
line con 0
stopbits 1
line vty 0 4
scheduler max-task-time 5000
Can somebody tell me what I'm doing wrong?
Guus Cramer
Re: ATM interface doesn't come up
Your question is not clear buddy...
I will try to clear myself better then.
First, I still don't have my ATM interface up. Despite changes I've made to the config.
I thought that the Interface should come up (CD-led burning green) when the Cisco827 is attached to the ADSL line. That should happen initially.
As, it isn't clear whether it is CHAP or PAP. I tried both. But the reulst stayes the same. No burning CD-led greeen.
Now, my config looks like:
version 12.2
no service pad
hostname VPN_CRS-01
enable password 7 020D0B5D0D0F0A
username ciris privilege 15 password 7 030F540D000624
no mmi pvc
ip subnet-zero
hash md5
group 2
crypto isakmp key intranet address xx.xx.xx.xxx
set peer xx.xx.xx.xxx
match address 100
interface Ethernet0
shutdown
hold-queue 100 out
interface ATM0
no ip address
no ip mroute-cache
pvc 0/35
dialer pool-member 1
interface Dialer0
ip address yyy.yyy.yyy.yyy 255.255.255.240
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap
ppp chap hostname ciris@demon.nl
ppp chap password 7 1427100301277F2873
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip pim bidir-enable
dialer-list 1 protocol ip permit
line con 0
stopbits 1
line vty 0 4
login
end
I hope I'm what clearer now for you. If not, please tell. The ISP isn't very coorperate to help. Due, we are installing a different router.
regards,
Guus Cramer
180
