06-17-2003 06:42 AM - edited 02-20-2020 10:48 PM
is auto proxy work on PIX like on IOS firewall, customer
wants to use to authenticate users on Raduis server passing thru PIX ?
thanks for any advice
JYP
06-17-2003 06:50 AM
Hi Jeanyves,
This will help you;
Yatin
06-17-2003 07:01 AM
hi Yatin
thanks for your quick response, i saw already this example
but don't know how to explicit redirect outside user to authenticate/authorize
on radius thru PIX ?
is it documented somewhere
thanks
JYP
06-17-2003 07:00 AM
Hi -
The following link will be useful to your customer:
http://www.cisco.com/en/US/tech/tk583/tk547/tech_configuration_examples_list.html
Hope this helps --
06-17-2003 07:11 AM
thanks also saw these article but didnt macht with Customer's configuration
Client without VPN client ==== >PIX 6.2 ===AAA==>Radius Server
JYP
06-17-2003 09:18 AM
What's not matching the requirement? The examples show 'outbound' authentication and authorization, if you need it for INBOUND users, then just changee the commands for inbound.
Is that the concern or something else?
thanks,
yatin
06-18-2003 02:13 AM
customer applied exactly same setup as reported in article
"performing authentication;authorization and accouting of users through PIX
Versions 5.2 and later"
but still doesnt work so did it really work with Raduis server ?
thanks for any comments
JYP
06-18-2003 07:23 AM
I should have quoted this earlier for clarity, but that is the very first line in the doc on the url I sent;
RADIUS and TACACS+ authentication may be done for FTP, Telnet, and HTTP connections. TACACS+ authorization is supported; RADIUS authorization is not.
yatin
06-18-2003 07:43 AM
thanks for your response customer finally find a configuration
that works with Radius Authorization !!! even not supported
but is very disapointed about security issue because he need
to apply an access-list whole open in this outside connection
in order to work like
access-list 101 permit tcp any any eq telnet ?
is it the correct configuration and safety one ?
thanks
JYP
