Backing up machines on DMZ
This is a 3 interface PIX 520 running 6.1(1).
The Backup server is on the 'inside'LAN (172.16.x.x) and the machines to be backed up are on the 'dmz' network (192.168.x.x). Problem is, the backup software does not tolerate any changing of the source of destination address (NAT). From a security standpoint, what would be the least compromising way to resolve this issue?
Many thanks for your time,
Farhad
Re: Backing up machines on DMZ
have you tried the static (inside,dmz) 192.168.x.x 172.16.x.x
(if you use NAT make sure the addresses do not overlap with the static ones
and open the ports required for the backup software.)
If it does not work, switch to a new backup software. Which one are you using?
You don't have to NAT between DMZ and internal. Just route the packets and open the appropriate ports with an access-list. Your access-list can contain the IP addresse of both servers (the backup and the service server).
I've a similar , I think , problem.
Three interfaces
outside 213.x.x.x
inside 192.168.1.x
dmz 172.16.1.x
One host in the DMZ with several local IP address ( 172.16.1.1-10 ) which hosts 10 web servers.
These WWW are static natted to outside IPs 213.x.x.1-10
One host in the inside interface with some other web server ( don't ask me why .. ) natted to the outside with different IPs.
Problem is .
From inside I cannect connect to web server's outside IP
The TAC told me to usethe static command with the inside address for both the inside and dmz interfaces:
static (inside,dmz) 172.16.2.9 172.16.2.9 netmask 255.255.255.255
Then I opened the ports referencing the same 172.16.2.9 addr and it worked. This creates a bit of the security risk but in this instance, it may be the least painful solution.
Thx for your responses.
-f
116
