Bandwidth Policy on a Lan-to-Lan VPN
When I try to setup Bandwidth Policy on a Lan-to-Lan VPN I get the following error. I have a VPN Concentrator 3015 on each side.
An error has occurred while attempting to perform the operation.
Error updating bandwidth settings for LAN-to-LAN connection (General Error).
1 REPLY
Re: Bandwidth Policy on a Lan-to-Lan VPN
Make sure that you have a Bandwidth policy defined and then try applying it to the LAN to LAN tunnel. If you have followed Cisco document and are still seeing a problem, go ahead and open a TAC case and someone will troubleshoot this with you.
Hope this helps,
Thanks and Regards,
Aamir Waheed,
Cisco Systems, Inc.
CCIE#8933
137
