Basic setup problem - please help!
I am setting up my first PIX firewall, in a test network right now, and it is supposed to go into production in a few days.
I am trying to open up some ports for an inside server, doing everything "by the book" (cisco e-learning, to be exact) but I've had no success with that. Basically I am trying to map an inside server (192.168.254.199) to an outside IP (xxx.115.215.1) which is assigned to the outside interface. The type of traffic that should be passed to the inside server is remote desktop and http. (Other users are PATed to xxx.115.215.2) So I tried to use static/conduit pairs, as per e-learning stuff...
static (inside, outside) xxx.115.215.1 192.168.254.199
conduit permit tcp host xxx.115.215.1 eq www any
conduit permit tcp host xxx.115.215.1 eq 3389 any
After I type this, I can not access the internet from the server, or ping to the outside... and of course can not access remote desktop/web server from the outside either, which is the main goal.
Here is the config:
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pix
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside xxx.115.215.1 255.255.255.0
ip address inside 192.168.254.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 xxx.115.215.2
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
conduit permit icmp any any
route outside 0.0.0.0 0.0.0.0 xxx.115.215.125 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.254.100-192.168.254.150 inside
dhcpd dns 192.168.254.199 199.185.225.10
dhcpd wins 192.168.254.199
dhcpd lease 28800
dhcpd ping_timeout 750
dhcpd domain test.local
dhcpd enable inside
terminal width 80
Cryptochecksum:xxx
: end
pix#
I am sure the problem is something simple, as I am just a beginner...
Your help will be GREATLY apprechiated!
Thanks in advance
1 ACCEPTED SOLUTION
Re: Basic setup problem - please help!
great news ... I am glad it works now !!!
Please resolve the case so it shows up on the list as 'ticked' ... Cheers,
I for accessing the internal server from the internet you need to use POrt forwarding please use the below command.
static (inside,outside) tcp interface 3389 192.168.254.199 3389 netmask 255.255.255.255
For remot desktop.
static (inside,outside) tcp interface 80 192.168.254.199 80 netmask 255.255.255.255
For http
I suggest you NOT to use conduit but use access-list instead so ..
access-list Outside-In permit tcp any host xxx.115.215.1 eq 3389
access-list Outside-In permit tcp any host xxx.115.215.1 eq 80
apply the access list to the outside interface
access-group Outside-In in interface outside
The PAT seems OK .. I hope it helps ... please rate it if it does !!!
Dear Sir,
Thanks to your kindness, here I am, posting from within my test server, accessed by RDP!
After several hours of sheer frustration, I must say your reply was precise, purposeful and right on the money!
Thanks again,
Sean
120
