Basic VPN Setup (HELP!)
Okay, maybe I'm just acting brain-dead here, but I really need some help. Here's my situation: I'm trying to set up a basic VPN tunnel from my network (running over an 1841 with the advsecurity IOS) to a remote network. Here's the caveat: that remote network has used every single private IP address that exists already, so we can't use any of them. Obviously, our network needs to NAT a public IP address across the tunnel so that the remote network will not get confused, since our network is using 192.168.1.0/24. I was told I only needed a very simple, basic VPN. The settings I was given from this remote network's admin were as follows:
3des encryption with MD5 integrity
IKE encryption and Diffie-Hellman Group: 3DES with Group 2
Aggressive mode ISAKMP initial contact payload: disabled
Compression: Disabled
Rekey timeout: 08:00:00
Rekey data count: (None)
Keepalive interval: 00:01:00
Keepalive (On-demand connections): Disabled
Anti Reply: Enabled
IPsec DFBit: Clear
I'm really beating my head against the wall here, so here, let me dump the config here (edited for length and private IPs) and hopefully you guys can help me!
Building configuration...
Current configuration : 4829 bytes
version 12.4
service password-encryption
hostname PeotaRouter
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.168.1.150 192.168.1.254
ip dhcp pool sdm-pool1
import all
network 192.168.1.0 255.255.255.0
domain-name ourdomain.com
dns-server DNS1 DNS2
default-router 192.168.1.1
ip name-server DNS1
ip name-server DNS2
(snip for length)
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key (our psk) address (far end router IP)
crypto isakmp keepalive 60
crypto ipsec transform-set tunnel esp-3des
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address (ext ip) 255.255.255.0
ip nat outside
no ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description $ES_LAN$
ip nat inside
duplex auto
speed auto
ip default-gateway (our gateway ip)
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool ovrld (our ext ip) (our ext ip) netmask 255.255.255.0
ip nat inside source list 7 pool ovrld overload
ip nat inside source static network 192.168.2.1 (ext ip for vpn) /32
ip nat outside source static tcp (our ext ip) 407 192.168.1.227 407 extendable
ip nat outside source static udp (our ext ip) 407 192.168.1.227 407 extendable
ip nat outside source static tcp (our ext ip) 1417 192.168.1.227 1417 extendable
access-list 7 permit any
access-list 23 permit 192.168.1.0 0.0.0.255
access-list 111 permit ip host 192.168.1.104 host (ip of machine on other end of tunnel)
control-plane
banner login ^CC
(snip for length)
^C
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
end
Re: Basic VPN Setup (HELP!)
Bump
Why are you setting your default route to an interface and not the default gateway IP?
Can you actually access the Internet via this router?
I'm not understanding where the 192.168.2.x network is coming from either:
"ip nat inside source static network 192.168.2.1 (ext ip for vpn) /32"
114
