Basic Zone Firewall not working
Hello, I configured the zone based firewall as shown below (it is a C2811 router).
Topology is:
Webserver(IP:10.2.0.100)----layer2switch----(fa0/0 IP:10.2.0.1) C2811 (fa0/1:10.4.0.1) ------------layer2switch---------clientPC(IP:10.4.0.4)
Behavior:
Before applying class-map, I could ping webserver to clientPC and vice versa OK.
Issue:
I applied the config as below. I was expecting that only http traffic would go through the zonefw.
Instead, all traffic continues to flow normally. What is wrong?
hostname zonefw
no ip domain-lookup
class-map type inspect match-all http
match protocol http
policy-map type inspect http
class type inspect http
  inspect
zone security internal
zone security external
zone-pair security myinbound source external destination internal
service-policy type inspect http
zone-pair security myoutbound source internal destination external
interface FastEthernet0/0
ip address 10.2.0.1 255.254.0.0
zone-member security internal
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.4.0.1 255.254.0.0
zone-member security external
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
Hall of Fame Super Silver
You did not configure (or did you remove intentionally?) a class class-default. This is used by the firewall to drop (default behavior) and traffic not matching the earlier referenced class(es).
Reference.
I see the class-default is hidden, but when I do the command below, they show up. Still no success though, it seems the class-map http is not even getting hits. All protocols are allowed at this point. Any ideas?
zonefw#sh policy-map type inspect zone-pair sessions
Zone-pair: external-internal
  Service-policy inspect : http
    Class-map: http (match-all)
      Match: protocol http
      Inspect
    Class-map: class-default (match-any)
      Match: any
      Drop (default action)
        0 packets, 0 bytes
Zone-pair: internal-external
      Inspect
      Match: any
        0 packets, 0 bytes
That does look odd. You do have the prerequisite security license, yes?
650
