Best Practice for where to apply ACL's on a router
ChrisCopley_2
I have a 1760 router with a 4 port ethernet card. It has the Vlan1 int on it for f0/0 in the IOS. I need to apply an ACL to that interface/subnet with the phyical cable in f0/0 and ip range of vlan1. When appling the ACL should I apply it to the physical interface or the Vlan (mgt) interface. What is the best practice and is there any docs on this on cisco?
Chris
Richard Burts
Chris
The f0/0 is operating as a switch port and as such you can not apply the access list directly to the physical interface. You should apply the access list to the vlan interface.
Rick
Rick
Thanks, that makes sense
