Best way to config a PIX without NAT
tkpsimon
I have tried, "NAT (inside) 0 x.x.x.x 255.255.255.0"
it's working, but some how outside host cannot access anything behind the pix unless the inside machine start a session to outside first.
Any idea why this happen? is this normal?
any idea would be appreciate.
mostiguy
Level 6
Level 6
That is normal - you need to write an access list to open ports, and apply it to the outside interface
Thanks for your reply,
actually i already have ACL apply on the outside interface, let set permit icmp any any. But problem still happen to be that way, always require inside host to initial traffic, then outside can access.
I understand this is not a big of issue, but for web server, it's kind of annoying. We always need to send out icmp to outside.
You need to a nat 0 rule with an access-list for this to work.
For example:
nat 0 (inside) access-list no-nat
access-list no-nat permit ip 10.10.0.0 255.255.0.0
atdhingr
you need a static and an ACL for outside users to initiate a connection inside:
static(inside,outside)
access-list 101 permit ip any
access-group 101 in interface outside
