We have BGP peering with two ISP's (ISP A and ISP B). Both the ISP's are connected on a same border Router on different interface. Both ISP are directly connected and connected routes can be seen in routing table.
We are receiving default-routes from both the ISP's. We have advertised our IP prefix to both the ISP's (103.XX.XX.XX/24) subscribed from APNIC . We have configured route-map and called in bgp neighbor to make ISP A as primary.
interface gig 0/0/0
des. ISP A
ip address xxx.xxx.xxx
interface gig 0/0/1
des. ISP B
route-map ISPB-in permit 10
set local-preference 80
route-map ISPB-out permit 10
set as-path prepend 132407 132407 132407 132407
Above route map has been called to bgp neighbor with ISP B
Now, the problem we are facing is we are not able to ping IP of interface gig 0/0/1 from internet, where IP of ISP B has been configured .
Howerver the ping is reachable from outside if the interface gig 0/0/0 ( ISP A) is shutdown.
