Big problem with importing configuration to the CSPM
I have a big problem!
1- I've installed CSPM as a standalone in my workstation.
2- I've imported the configuration of a network by "Config Import Tool". This generates an xml file.
3- I've made "Import configuration from CSPM. But when I click to a device, specially a PIX, this generates a Dr Watson Error which is :
"An application error has occured and an application error log is being generated
Cfmi.exe
Exception : access violation (0xc0000005), address 0x118c5930 "
And in the log file, I found :
"Warning:CSPM server and management address not available. Setting it to 0 for device->PIXTest"
I suppose that is a problem related to the GUI, as the process Cfmi.exe is for the GUI interface.
In addition, in the Event viewer, I've had these errors, related to the installation
a- The description for Event ID ( 0 ) in Source ( CSPM ) could not be found. It contains the following insertion string(s): CtErr: Can't open reg key 0. (Twice)
b- Syslogger unable to initialize.
Although, I've started from the beginning, I mean that I've installed properly :
- Windows NT Server 4.0
- Internet Explorer from the CSPM CD.
- Service pack 6.0 from the CSPM CD.
- CSPM.
I wonder what I can do to avoid this problem, because I've managed to work with CSPM, but with this error I can't work with it.
Thank you very much in advance.
I'm waiting for your response impatiently.
Silver
Re: Big problem with importing configuration to the CSPM
I wonder if it's a conflict with other software on the machine or a permissions issue. I would definitely open a case with Cisco on this. Let me know what you find!!!
The first thing you need to do when you import a configuration from an other machine ist to correct the settings of your CSMP node.
Either move it to the right subnet
Or create a new CSPM Host in the subnet you are in and change the Settings in your managed Devices.
154
