Community Member
Block a specific URL with Acess Lists
Is it possible to block a specific URL using Access lists, or do you have to use the IP?
TIA,
Alexi
1 REPLY
Community Member
Re: Block a specific URL with Acess Lists
Hi Alexi,
yes you can do it with IOS Routers similar like blocking the "Code Red Worm". Look at http://www.cisco.com/warp/public/63/nbar_acl_codered.shtml#acl
Modify the class-map to your needs, build a policy-map and handle matching policies in the access-list.
URL blocking on a pix is possible only in conjunction with a websense server running. For information look at http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_62/cmdref/tz.htm#xtocid5
112
