10-01-2009 06:56 PM - edited 03-09-2019 10:36 PM
What ports of foxy used ? If I want block foxy running by user , how should I do ?
thanks
10-02-2009 09:34 AM
You should start by not allowing people to install software themself on your pc's. Then you should make sure that no one can connect a pc to your network, unless you have control over it.
10-04-2009 06:36 PM
Dear Sir ,
If foxy had been installed by user , how do I block it ?
thanks
