Community Member
Block Foxy by CSA
What ports of foxy used ? If I want block foxy running by user , how should I do ?
thanks
Re: Block Foxy by CSA
You should start by not allowing people to install software themself on your pc's. Then you should make sure that no one can connect a pc to your network, unless you have control over it.
Community Member
Dear Sir ,
If foxy had been installed by user , how do I block it ?
thanks
150
