03-26-2002 10:04 AM - edited 03-08-2019 10:09 PM
I want to be able to block my clients from any unwanted ip address and/or ports. I've tried using a "conduit deny" but it didn't work. any ideas?
Hardware:
Pix 506
IOS:
Ver. 5.2
03-26-2002 11:46 AM
you can use
outbound apply command
for e.g denying users to this ip 205.188.245.121 for http
outbound 12 deny 205.188.245.121 255.255.255.255 80 tcp
apply (inside) 12 outgoing_dest
03-26-2002 04:46 PM
I'm using version 6.1.3 - you can issue
pix(conf)# "shun 123.123.123.123"
this will deny that web address from reaching user.
04-05-2002 06:07 AM
Here's an example that would only allow your clients to use HTTP and telnet:
access-l acl_in permit tcp any any eq www
access-l acl_in permit tcp any any eq telnet
access-g acl_in in interface inside
The implicit deny will block everything else. I don't recall which IOS version introduced access-list support, so you may have to upgrade. Hope this helps.
04-08-2002 06:48 AM
you can configure access-list instead the conduits or, if you use a firmware after a 6.0 you can use
the shunning command.
Bye,
Graz.
04-08-2002 10:57 AM
Thanks for all the input.
What I was trying to accomplish was to be able to shutdown access Morpheus and other internet based applications on our network. It was getting to the point that band width was a minium.
I ended up using the outbound and apply commands to do this. Restricting all connections except some specific ports. The only thing is, I can see this possiblly becoming a management nightmare in the future.
Thanks again
04-08-2002 11:08 PM
hi,
for bloking Morpheus and other kazaa application you must to deny the access at the destination tcp port 1214.
regards,
graz.
