Bridging two Novell 5 servers using VPN Connection
I was wondering if this can be done.
Two networks running Novell5 servers bridged by PIX501 devices running VPN server. Ultimately, I want to achieve a secure tunnel between the two servers.
I have tested with the citrix solution, but no good due to remote printing issues.
Anybody have any ideas?!
Travis,
Re: Bridging two Novell 5 servers using VPN Connection
Hi Travis,
IPSEC tunnel between two PIX only can pass unicast IP traffic.
The only way I think you can do is through DLSW which can encapsulate bridge traffic into TCP port 2065, then you can pass the traffic through the VPN tunnel.
If Novell 5 has something like DLSW, it will be fine, otherwise, it can not be done.
Please check in following URL:
http://www.cisco.com/warp/customer/707/dlsw.shtml
http://www.cisco.com/warp/public/697/3.html
Best Regards,
I'll look at DLSW. Thank you,
Travis,
86
