Community Member
Bug CSCdw55565 questions?
Hi guys,
I just finish upgrade my ACS from 2.4 to 3.0(2) a couple days ago, and i found this bug which is also the problem that i'm having too, does anyone ever try to resolve this bug with the workaround that suggest from Cisco. The reason is, i can't even find the registry information which it mention in there. any idea would be appreciate! thank you.
Simon
1 REPLY
Community Member
Re: Bug CSCdw55565 questions?
Be sure that basic tacacs+ accounting is configured or you will not be able to modify the registry keys specified.
89
