09-01-2003 04:33 AM - edited 03-09-2019 04:37 AM
Hi All
I would like to install firewall(Built in) on Cisco 3600.
Any one has any idea how to install and configure it.
Thanks in advance
Sukrut
09-01-2003 06:20 AM
Sukrut,
You could try starting with:
http://www.cisco.com/cgi-bin/Support/browse/psp_view.pl?p=Software:Cisco_IOS_Firewall
Best regards.
Alex
09-01-2003 11:46 AM
Hi ,
To clear your question, there is no " build in " firewall for cisco 3600 router. It's the image that you run on this router support IOS firewall feature set.
The feature set you are looking for is IP/FW. (IP/FW/IDS)
Also when you do show version,
"c3600-io3-mz.122-15.T7.bin" , " o " is the one for firewall.
The concept for IOS firewall is to apply access list to outside interface for inbound direction with the rule deny ip any any, which will deny all the traffic coming into the network. and apply ip inspect to either inside interface for inbound direction or outside intreface for outbound direction to allow the return traffic initiate from inside to come back in.
Tony
09-01-2003 02:06 PM
Basically, it's all dependant on the feature set of your router. You will need to purchase the firewall feature set for your router. What you are looking to buy is SMARTnet for your 3600 with IOS upgrades or the software feature set you are looking for. In the UK, the IP/FW feature set IOS costs about £550 and the part number is CD36-CH-12.x.x where x.x relates to the most current IOS version. Your other option is to get SMARTnet CON-SW-VPKG7 (3620) or 10 (3640) or 13 (3660) which will cost between £300 and £700 depending on which model you need it for, however, this will give you unlimited software feature upgrades for the whole year.
HTH,
S
