Bytes received: 0 after connecting
I am able to connect from my office via the VPN Client version 4.8.01.300. After I connect I am not able to conncect to my company's central server via Remote Desktop Connection and I lose my internet connection. The bytes received: 0. I have a DSL Internet connection at this location.
I brought the computer at and connected to the VPN Client and Remote Desktop Connection and the Internet without any problems. I am using cable Internet at this location.
What is the problem and how do I resolve it? Thank you.
Re: Bytes received: 0 after connecting
You might be facing the MTU issue. I would suggest you to run a ping test using the command :
ping -l -f 1500
You should see something like :
Packet needs to be fragmented but DF set.
Keep lowering the packet size by 100 and see where you get the response. Then run the setMTU.exe application and set the mtu for the physical adapter that connects you to the internet. Please be informed that you'll be required to reboot the PC.
Please test and let me know how it goes.
HTH,
Please rate the post if you think it is helpful.
Kamal
Kamal, thank you for your response. I pinged the server from the client and all packets were sent and received with 0% loss.
Do you have any other suggestions?
In your office yu might be going through a patted ip address. The VPN headend device should have NAT-T enabled, and on the client , please make sure you have "Enable Trnsparent Tunneling" checked.
HTH,
-Kanishka
Hi Kanishka, thank you for your response. I am using "IPSec over UDP for NAT transparency" on the client. I do not have any control over the server.
I am still having the same problem. Do you have any other suggestions?
335
