08-30-2010 12:40 AM - edited 02-21-2020 04:04 AM
I have two CAS pair for wired and wireless (total is 4) but when I upload licenses it shows me server count is 1, should it be mentioned below as 2? plus Im facing issues while adding other CAS pair.(it gives me "SSLManager: server's certificate chain verification failed " error however I have exported/imported CAM/CAS cert to each other.
FlexLM License-Enabled FeaturesStandard Manager License presentManager Failover License presentOut-of-Band Server Count1Out-of-Band Failover Server Count
08-30-2010 09:02 AM
Nomair,
How many licenses have you uploaded on the CAM so far? If you have two HA CAS pairs, and one HA CAM pair, it should be a sum total of 3 licenses.
Can you verify? Go to your CAM SSH session, and type the following:
psql -h localhost -U postgres controlsmartdb -c 'select count(*) from flexlm_licenses;'
Faisal
08-30-2010 10:24 PM
Faisal bhai,
I have uploaded three license files
CAM Lic
1st CAS Pair
2nd CAS pair
But when I execute that command then it shows only two:)
[root@MOFA-CAM-1 ~]# psql -h localhost -U postgres controlsmartdb -c 'select count(*) from flexlm_licenses;'
count
(1 row)
09-01-2010 03:03 AM
Nomair,
Run this on your CAM and send me the file via email or PM:
\a
\o /root/Licenses.txt
select * from flexlm_licenses;
\q
This will create a file called Licenses.txt in your /root directory on your CAM. You can copy it to your local machine using WinSCP.
Also send me the output of the following command from your CAM (If in HA, then from both of your CAMs labelling which one is primary and which is secondary)
ifconfig eth0
HTH,
Faisal
