CAMs does not work in a cluster
Tell  me please, I have two Cams worked in a cluster on version 4.1.8, after  updating to version 4.8.0, interfaces, synchronization can not see each  other and the tab failover each CAM neighbor is not active (dead)
Sincerely, Alexander
1 ACCEPTED SOLUTION
Re: CAMs does not work in a cluster
Alexander,
Check your certificates. Install the same certificate/private key pair on both CAMs.
More details here:
https://supportforums.cisco.com/docs/DOC-12609
Also other certificate related documents are available here:
https://supportforums.cisco.com/community/netpro/security/others?view=documents
HTH,
Faisal
If you find this post helpful, please rate so others can find the answer easily
Alexander,
More details here:
HTH,
Faisal
Faisal,
Thank you very much, it worked for your advice!
I could see two possibilities:
a) Certificates issues, as Failsal said
b) Check by using "vi" that the insterfaces that you use for heart beat still the same as 4.1.8
Juan Huicab Internetworking juan.huicab@nextiraone.com.mx T 52 (81) 1001 8000 E 8015 C 52 (81) 1077 2435 San Pedro Garza García, N. L. México www.nextiraone.com.mx
339
