Can I cross two VPNs on two interfaces?
Please see the attached pdf diagram.
I can successfully pass traffic from 192.168.60.0 to the DMZ and Inside networks.
I can successfully pass traffic from 192.168.20.0 to the DMZ and Inside networks.
Problem – I cannot pass traffic from either network across both VPNs. For example, I cannot go from 192.168.60.0 to 192.168.20.0, or vice versa.
Any ideas as to why this won't work?
Thanks in advance.
1 ACCEPTED SOLUTION
Gold
Re: Can I cross two VPNs on two interfaces?
just wondering if both router 1751 and pix 501 have no-nat and crypto acl include each other subnet. also, on the pix 515, both subnets need to be included for both lan-lan vpn.
e.g.
on router 1751,
access-list no_nat 192.168.20.0 0.0.0.255 172.24.0.0 0.0.0.255
access-list no_nat 192.168.20.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list no_nat 192.168.20.0 0.0.0.255 192.168.60.0 0.0.0.255
access-list lan2lan 192.168.20.0 0.0.0.255 172.24.0.0 0.0.0.255
access-list lan2lan 192.168.20.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list lan2lan 192.168.20.0 0.0.0.255 192.168.60.0 0.0.0.255
on pix 501,
access-list no_nat 192.168.60.0 255.255.255.0 172.24.0.0 255.255.255.0
access-list no_nat 192.168.60.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list no_nat 192.168.60.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list lan2lan 192.168.60.0 255.255.255.0 172.24.0.0 255.255.255.0
access-list lan2lan 192.168.60.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list lan2lan 192.168.60.0 255.255.255.0 192.168.20.0 255.255.255.0
for pix 515,
access-list vpn1_1751 permit 172.24.0.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list vpn1_1751 permit 192.168.1.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list vpn1_1751 permit 192.168.60.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list vpn2_501 permit 172.24.0.0 255.255.255.0 192.168.60.0 255.255.255.0
access-list vpn2_501 permit 192.168.1.0 255.255.255.0 192.168.60.0 255.255.255.0
access-list vpn2_501 permit 192.168.20.0 255.255.255.0 192.168.60.0 255.255.255.0
the only bit i am not sure is the no-nat on pix 515. i guess we should give it a go first, then figure the no-nat out by troubleshooting.
1 REPLY
Gold
e.g.
on router 1751,
on pix 501,
for pix 515,
96
