Can not access inside hosts over tunnel.
My setup:
Windows network <-> PIX 501 <-> cable modem <-> internet <-> vpn client.
I have set up split tunneling so my vpn user can browse the net whilst connected. That portion is working fine. However, the only host on the inside of the pix that the vpn can access is the machine that happens to be all-in-one radius server/wins server/dns server. I can access that system's file shares, but not any other box. The inside interface uses 192.168.0.0. The vpn client ip pool is 10.1.1.0.
I am not able to ping anyone except the above mentioned box.
Thanks for the help.
Chris Lincoln
  • Other Security Subjects
Gold
Re: Can not access inside hosts over tunnel.
just wondering if the default gateway for all windows network host is the pix501 inside interface.
also, have a read of the same codes below:
access-list 101 permit ip 192.168.1.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list 120 permit ip 192.168.1.0 255.255.255.0 10.1.1.0 255.255.255.0
nat (inside) 0 access-list 101
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp identity address
isakmp nat-traversal 20
crypto ipsec transform-set vpnset esp-3des esp-md5-hmac
ip local pool ippool 10.1.1.11-10.1.1.21
vpngroup vpnclient address-pool ippool
vpngroup vpnclient idle-time 1800
vpngroup vpnclient dns-server 139.130.4.4
vpngroup vpnclient password cisco456
vpngroup vpnclient split-tunnel 120
crypto dynamic-map dynmap 10 set transform-set vpnset
crypto map remote_vpn 20 ipsec-isakmp dynamic dynmap
username cisco password cisco123
aaa-server LOCAL protocol local
crypto map remote_vpn client authentication LOCAL
crypto map remote_vpn client configuration address initiate
crypto map remote_vpn client configuration address respond
if further assistance is needed, please post the config.
jackko,
Thanks for the time.
Actually, no. Some of the inside hosts use a second pix501. I am not sure how/why it works the way it does, but it does. For what its worth, before I tried enabling split-tunnelling, I had everyone, including the vpnclient ip pool, on the 192.168.0.0 network. That worked, except split-tunnelling didn't.
Attached is my config. I hope I am not exposing my privates.
Problem solved. I did not have the physical connection that I thought I had.
110
