Community Member
Can Not Do Drive Mapping after VPN is connected via PIX515
Dear Sir,
Below is our VPN configuration applied on PIX 515 Firewall. It works when I dialed IP address of PIX to establish VPN connection from NT server. But I can not do drive mapping after VPN connection is established. (I mapped to \\Server's IP\Sharename, not use server name)
The inside network ip address is from 192.168.100.1 to 192.168.100.254
The local pool IP defined on PIX is 192.168.101.1 to 192.168.101.254
Can someone help me to find out if I miss anything from the following configuration? Thanks. -Simon
ip local pool iprange 192.168.101.1-192.168.101.254
vpdn group 1 accept dialin pptp
vpdn group 1 ppp authentication chap
vpdn group 1 ppp authentication mschap
vpdn group 1 ppp encryption mppe auto
vpdn group 1 client configuration address local iprange
vpdn group 1 client authentication local
vpdn group 1 client configuration dns 192.168.100.30
vpdn group 1 client configuration wins 192.168.100.30
vpdn username cisco password vpn
vpdn enable outside
Access-list 101 permit ip 192.168.100.0 255.255.255.0 192.168.101.0 255.255.255.0
NAT (inside) 0 access-list 101
sysopt connection permit-pptp
sysopt connection permit-l2tp
VIP Purple
Re: Can Not Do Drive Mapping after VPN is connected via PIX515
I would check to make sure WINs is working properly. Log in via the VPN, and query the WINS server to make sure you see your workstation in it.
I'm guessing that you wont, which probably means you can't use WINs to lookup the name of the server.
The other obvious thing to do is to verify that the server also appears in the WINs database.
Community Member
Thank you very much Sir. I will try it.
99
