Community Member
Can not ping or rdp
I am connected through the Cisco VPN clinet to a cisco PIX firewall. it works fine if you connect to the pix lcoation other than the office, but if you connect from the office behind the another pix firewall, it is connected but you can not rdp or ping the ip of the other side of the pix.
1 REPLY
Silver
Re: Can not ping or rdp
you cant ping the IP address of the other side by design. Can you ping any other IP?
thanks
Nadeem
101
