Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Can PIX be configured for VPN using IPSec and PPTP at the same time ?
Dear Sir,
We have 2 PIXen (PIX525 and PIX515). Both PIXen are configured for VPN Remote Access using PPTP and working good. Now we want to add Site-to-Site VPN using IPSec on both PIXen by following this doc link http://www.cisco.com/warp/public/110/38.html
I have experienced the following problem:
1. I need two "NAT (Inside) 0" statement for two different access-list #. One ACL# is for PPTP VPN and one ACL# is for IPSec VPN. But PIX only accepts one "NAT (Inside) 0" statement. The second "NAT (Inside) 0" statement will overwrite the first one. What Can I do?
Access-list 101 permit ip 192.168.100.0 255.255.255.0 192.168.101.0 255.255.255.0 (for PPTP VPN traffic)
access-list 102 permit ip 192.168.100.0 255.255.255.0 172.16.0.0 255.255.0.0 (for IPSec VPN traffic)
nat (inside) 0 access-list 101
nat (inside) 0 access-list 102
PIX can only accept one NAT(0) statement above.
2. If I combine both VPN traffic into one ACL# and use one "nat (inside) 0" statement, my PPTP VPN for remote access will not work because of "crypto map mapname 1 match address 101" statement in IPSec configuration.
access-list 101 permit ip 192.168.100.0 255.255.255.0 172.16.0.0 255.255.0.0 (for IPSec VPN traffic)
My PPTP VPN will not work with above "crypto map mapname 1 match address 101" statment. If "crypto map mapname 1 match address 101" statement is removed, then PPTP VPN will work fine.
Can someone help me to resolve above issue?
Simon
Re: Can PIX be configured for VPN using IPSec and PPTP at the sa
Yes, you can do this, you need to create a couple of access-lists though.
First off, as you said, combine your two "nat 0" acl's into one ACL as follows:
access-list nonat permit ip 192.168.100.0 255.255.255.0 192.168.101.0 255.255.255.0
access-list nonat permit ip 192.168.100.0 255.255.255.0 172.16.0.0 255.255.0.0
nat (inside) 0 access-list nonat
Then have your crypto ACL simply point to a new access list that only defines your crypto traffic as follows:
access-list 100 permit ip 192.168.100.0 255.255.255.0 172.16.0.0 255.255.0.0
crypto map mapname 1 match address 100
As you can see, you just have to separate your nat 0 ACL from your crypto ACL, they don't have to be the same, and in your case, they can't be.
Thank you very much for your help. That resolved my problem to access VPN using PPTP. But for some reason, my VPN using IPSec did not work. I have followed this doc link
to config my PIX-to-PIX VPN using IPSec.
Can you provide me some idea why my IPSec did not work by looking at the "sh ipsec sa" and "sh isakmp sa" below?
Thanks again.
pix# sh ipsec sa
interface: outside
Crypto map tag: mwavemap, local addr. 4.67.22.2
local ident (addr/mask/prot/port): (172.16.0.0/255.255.0.0/0/0)
remote ident (addr/mask/prot/port): (192.168.100.0/255.255.255.0/0/0)
current_peer: 65.197.235.2
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest 0
#pkts decaps: 27, #pkts decrypt: 27, #pkts verify 27
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 4.67.22.2, remote crypto endpt.: 65.197.235.2
path mtu 1500, ipsec overhead 56, media mtu 1500
current outbound spi: b9dc9bd7
inbound esp sas:
spi: 0x67b1c19c(1739702684)
transform: esp-des esp-md5-hmac ,
in use settings ={Tunnel, }
slot: 0, conn id: 1, crypto map: mwavemap
sa timing: remaining key lifetime (k/sec): (4607989/25998)
IV size: 8 bytes
replay detection support: Y
inbound ah sas:
inbound pcp sas:
outbound esp sas:
spi: 0xb9dc9bd7(3118242775)
slot: 0, conn id: 2, crypto map: mwavemap
sa timing: remaining key lifetime (k/sec): (4608000/25899)
IV size: 8 bytes
outbound ah sas:
outbound pcp sas:
pix# sh isakmp sa
Total : 1
Embryonic : 0
dst src state pending created
4.67.22.2 65.197.235.2 QM_IDLE 0 0
Auto output from local PIX
ISAKMP (0): deleting SA: src 65.197.235.2, dst 4.67.22.2
ISADB: reaper checking SA 0x83df8f00, conn_id = 0
ISADB: reaper checking SA 0x83dffbc0, conn_id = 0 DELETE IT!
VPN Peer: ISAKMP: Peer ip:65.197.235.2 Ref cnt decremented to:3 Total VPN Peers:
Auto output from peer PIX:
ISAKMP (0): speaking to another IOS box!
return status is IKMP_NO_ERROR
crypto_isakmp_process_block: src 65.197.235.2, dest 4.67.22.2
OAK_MM exchange
ISAKMP (0): processing ID payload. message ID = 0
ISAKMP (0): processing HASH payload. message ID = 0
ISAKMP (0): SA has been authenticated
ISAKMP (0): ID payload
next-payload : 8
type : 1
protocol : 17
port : 500
length : 8
ISAKMP (0): Total payload length: 12
ISADB: reaper checking SA 0x83df8f00, conn_id = 0 DELETE IT!
Going by your output the tunnel is up between the two PIX's. These lines:
indictae that this PIX has received 27 packets over the tunnel and has decrypted them, but it has received no packets from the local network (172.16.0.0) to go to the remote network (192.168.100.0). Check the 172.16.0.0 network and make sure there's a route to the 192.168.100.0 network that points to this PIX. Also make sure this PIX has a route for the 192.168.100.0 network pointing out the outside interface (the default route will encompass this if there's nothing more specific).
Basically it looks like a routing problem, or you might still have your nat 0 ACL messed up, make sure it is correct and includes a line like the following:
access-list nonat permit ip 172.16.0.0 255.255.0.0 192.168.100.0 255.255.255.0
Pay particular attention to the subnet masks, it's easy to get those wrong and overlook them.
Thank you Sir for your reply. Looks like I am almost there.
I have listed my config below and have following questons:
1.Check the 172.16.0.0 network and make sure there's a route to the 192.168.100.0 network that points to this PIX.
My answer: I believe I do. As you can see the config below, 172.16.1.1 is the inside interface IP address and is also my default gateway for all PCs at 172.16.0.0 network. So the route to the 192.168.100.0 network should be sent to default gateway on PIX inside (172.16.1.1).
2.Also make sure this PIX has a route for the 192.168.100.0 network pointing out the outside interface.
My answer: I am not sure if I have this route. Can you show me what is the command for this or how to check it? The only route command I have is "route outside 0 0 4.67.22.1 1".
3.According the output below, what kind of packets is that? Are they IKE/IPSec negotiation packets or real data packets? The 27 packets are auto showed up and I did not trigger VPN traffic.
4.How do you trigger the VPN traffic to test the VPN? What I did is to access web server at 192.168.100.0 network from PC at 172.16.0.0 network. Is this correct?
5. Below is my PIX config for IPSec: (PPTP is not listed b/c it is working.) Peer PIX has identical IPSec config except some IP is set for peer PIX.
interface ethernet0 100full
interface ethernet1 100full
ip address outside xx.xxx.xxx.2 255.255.255.0
ip address inside 172.16.1.1 255.255.0.0
nat (inside) 1 172.16.0.0 255.255.0.0
global (outside) 1 4.67.22.201-4.67.22.254 netmask 255.255.255.0
fragment chain 1 outside
fragment chain 1 inside
access-list acl_out permit udp any host 4.67.22.11 eq 53
access-list acl_out permit udp any host 4.67.22.12 eq 53
access-group acl_out in interface outside
access-list 101 permit ip 172.16.0.0 255.255.0.0 192.168.100.0 255.255.255.0
sysopt connection permit-ipsec
crypto ipsec transform-set mwaveset esp-des esp-md5-hmac
crypto map mwavemap 1 ipsec-isakmp
crypto map mwavemap 1 match address 101
crypto map mwavemap 1 set peer 65.197.235.2
crypto map mwavemap 1 set transform-set mwaveset
crypto map mwavemap interface outside
isakmp enable outside
isakmp key ciscopix addressxxxx netmask xxxx
isakmp identity address
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 1
isakmp policy 1 lifetime 1000
93
