Can't establish tunnel between Pix 515 (6.3(1)) and Netscreen
It seems that from the Netscreen point of view, phase 1 is correct but keeps rebooting, and for the pix, I get debug messages I don't fully understand (like what means PEER_REAPER_TIMER). But it seems to me that even phase 1 fails.
Here is the logs
KEYENG_IKMP_SA_SPEC
isadb_create_sa:
crypto_isakmp_init_phase1_fields: initiator
is_auth_policy_configured: auth 4
gen_cookie:
ipsec_db_add_sa_req:
ipsec_db_get_ipsec_sa_list:
ipsec_db_add_ipsec_sa_list:
construct_header: message_id 0x0
construct_isakmp_sa: auth 1
set_proposal: protocol 0x1, proposal_num 1, extra_info 0x1
init_set_oakley_atts:
begin phase one
sa->state 0x0
ISAKMP (0): beginning Main Mode exchange
throw: mess_id 0x0
send_response:
isakmp_send: ip Gateway_FRA, port 500
PEER_REAPER_TIMER
P1RETRANS_TIMER
ISAKMP (0): retransmitting phase 1...
send_response:
PEER_REAPER_TIMER
P1RETRANS_TIMER
send_response:
PEER_REAPER_TIMERIPSEC(key_engine): request timer fired: count = 1,
(identity) local= 213.56.186.33, remote= Gateway_FRA,
local_proxy= 10.157.222.137/255.255.255.255/0/0 (type=1),
remote_proxy= 10.123.2.102/255.255.255.255/0/0 (type=1)
IPSEC(key_engine_sa_req): setting timer running retry <2>
crypto_ke_process_block:
KEYENG_IKMP_SA_SPEC
gen_cookie:
P1RETRANS_TIMER
send_response:
PEER_REAPER_TIMER
PEER_REAPER_TIMER
KEYENG_IKMP_SA_SPEC
gen_cookie:
P1RETRANS_TIMER
send_response:
PEER_REAPER_TIMER
QM_TIMER
ISAKMP (0): deleting SA: src 213.56.186.33, dst Gateway_FRA
REAPER_TIMER
ISADB: reaper checking SA 0x10dc7bc, conn_id = 0 DELETE IT!
crypto_gen_isakmp_delete:
isadb_free_isakmp_sa:
VPN Peer:ISAKMP: Peer Info for Gateway_FRA/500 not found - peers:0
ipsec_db_delete_sa_list_entry:
ipsec_db_free_ipsec_sa_list:
PEER_REAPER_TIMER
send_response:
PEER_REAPER_TIMER
QM_TIMER
REAPER_TIMER
PEER_REAPER_TIMERIPSEC(key_engine): request timer fired: count = 2,
crypto_gen_ipsec_isakmp_delete:
PEER_REAPER_TIMER
And here is the pix configuration:
: Saved
: Written by enable_15 at 11:01:34.182 UTC Mon Jun 30 2003
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
enable password zzzzzzzzz encrypted
passwd zzzzzzzz encrypted
hostname tgifirewall
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
name 194.206.224.141 Gateway_FRA
access-list Ping_Tous permit icmp any any
access-list VpnTgiToDti permit ip host xx.xx.xx.xx host yy.yy.yy.yy
access-list VpnTgiToDti permit ip host yy.yy.yy.yy host xx.xx.xx.xx
pager lines 24
logging console debugging
logging buffered debugging
icmp permit xx.xx.xx.pp 255.255.255.0 echo-reply outside
icmp permit any unreachable outside
icmp permit any echo-reply outside
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside zz.Zz.zz.zz 255.255.255.224
ip address inside xx.xx.xx.xx 255.255.255.0
ip address dmz pp.pp.pp.pp 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
no failover ip address dmz
pdm history enable
arp timeout 14400
global (outside) 1 yy.yy.yy.yy-yy.yy.yy.yy
global (dmz) 1 yy.yy.yy.yy-yy.yy.yy.yy netmask 255.255.255.0
nat (inside) 0 access-list VpnTgiToDti
nat (inside) 1 yy.yy.yy.yy 255.255.255.0 0 0
nat (dmz) 1 yy.yy.yy.yy 255.255.255.0 0 0
static (inside,dmz) yy.yy.yy.yy 10.157.222.0 netmask 255.255.255.0 0 0
access-group Ping_Tous in interface outside
route outside 0.0.0.0 0.0.0.0 213.56.186.35 1
route dmz yy.yy.yy.yy 255.255.255.0 192.168.137.2 1
route dmz yy.yy.yy.yy 255.255.255.252 192.168.137.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt ipsec pl-compatible
crypto ipsec transform-set SetDTI esp-3des esp-sha-hmac
crypto map VpnDTI 10 ipsec-isakmp
crypto map VpnDTI 10 match address VpnTgiToDti
crypto map VpnDTI 10 set pfs group2
crypto map VpnDTI 10 set peer Gateway_FRA
crypto map VpnDTI 10 set transform-set SetDTI
crypto map VpnDTI 10 set security-association lifetime seconds 3600 kilobytes 2000000
crypto map VpnDTI interface outside
isakmp enable outside
isakmp key xxxxxxxxxxxxx address xxxxxxxxxxx netmask 255.255.255.255
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 28800
telnet yy.yy.yy.yy 255.255.255.0 inside
telnet timeout 15
Could the problem come from an ADSL router situated after the firewall ?
If someone could help me solve my problem or even help me understand those debug logs that would be wonderful.
Thank you.
Thomas
Re: Can't establish tunnel between Pix 515 (6.3(1)) and Netscree
Is the ADSL router performing PAT ?
Thank you for your answer.
Yes actually, it does. What type of problem does it make? Cause nowhere in faqs, docs or forums have I seen that a router could do such things. But since that is my first vpn, it may have been a trivial matter that only I didn't know.
Thomas
YEEEHAAAA
It works know thanks to you. You where right it was a PAT issue. The way we found to make it work is the isakmp nat-traversal [seconds] command.
After two weeks of combat, man won over the machine.
Thank you again.
Thomas
Thomas,
I found that phase 1 will come up if you add the no-config-mode to your isakmp key statement. Try changing your statemet to this
isakmp key bonjour address Gateway_FRA netmask 255.255.255.255 no-config-mode
That should fix phase 1. If that works and you get through phase could you let me know.
Derek
Indeed it could have been that but as written above the main problem came from the NAT.
Furthermore, I don't think I used IKE mode configuration in this particular configuration.
But thanks for thinking of my problem ;-)
Thomas
472
