Community Member
Can't Seem To Connect To Webserver From Outside
I tried to searh for a similar topic and have tried different suggestions noted here and I can't seem to fix this problem.
I have a pix 506e and I'm trying to assign one of my assigned IP's from my ISP to my web server, which also has a static internal IP.
The following is my configuration settings:
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx
passwd xxx
hostname pixfirewall
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
access-list 101 permit tcp host xx.xx.xx.53 host xx.xx.xx.53 eq www log
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside xx.xx.xx.50
ip address inside
ip audit info action alarm
ip audit attack action alarm
pdm location inside
pdm location xx.xx.xx.53 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 10 xx.xx.xx.54-xx.xx.xx.62 netmask
global (inside) 1
nat (inside) 10 0 0
static (inside,outside) xx.xx.xx.53 netmask 0 0
access-group 101 in interface outside
route outside xx.xx.xx.49 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
terminal width 80
Basically I'm trying to connect my outside IP of xx.xx.xx.53 to my internal IP I have a feeling I did something wrong but I'm just not experienced enough to figure it out.
I also want to note that all the internal systems including the webserver can go out without issues.
Community Member
Re: Can't Seem To Connect To Webserver From Outside
The problem is with the ACL 101
change the line to
access-list test permit tcp any host xx.xx.xx.53 eq www log
access-group test in interface outside
This new ACL will allow connections from any external IP. Once it works , you can restrict access again to the allowed external IP addresses.
Youi can check your connections with
show conn
Hope this helps ... rate if it helps !
Community Member
It worked! Thank you for the help. Do you have any recommendations to try keep the webserver (and the rest of the servers behind the firewall) as secure as possible?
Community Member
Great ! It worked !
There are a couple of lines I dont understand , and in my opinion you should erase
1.- The configuration has some dhcp config , if you are not planning to use dynamic IP allocations do
conf term
clear dhcpd
2.- In my opinion this line global (inside) 1 is wrong
conf term
no global (inside) 1
3.- Change this line
nat (inside) 10 0 0
nat (inside) 10
this will allow outbound services only to IP addreses on the inside IP range.
4.- Enable ip verify on all interfaces as a security precaution.
conf term
ip verify reverse-path in interface inside
ip verify reverse-path in interface outside
Post a message if in doubt !
Bye !
Community Member
1.- Every time you modify a static command line you have to send a clear xlate , so any previous change will take effect .
do a
config term
clear local
clear xlate
this will interrupt all connections for a brief moment
2.- Check the web application from inside , from an internal workstation type
3.-From an external workstation browse by IP address not by domain name, at your browser type http://xx.xx.xx.53 if this works it will indicate a DNS resolution problem.
4.-Check the route table at your web server ( it should have a default route pointing to your internal PIX IP (
5.-Enable log
This will send all log information to your pix serial console , pix buffer , telnet/ssh terminal
conf term
logg mon 6
logg buff 6
logg mon 6
logg on
term mon
check the log at the moment you try to connect from an outside IP to correlate events.
Hope this helps ! Post any result
