I have two identical Pix515 each with 2 Ethernet (E0 and E1) unrestricted licenses.
E1 interface is configured as follow:
PIX Version 6.3(5)
interface ethernet0 100full
interface ethernet1 100full
interface ethernet1 vlan2 physical
interface ethernet1 vlan3 logical
interface ethernet1 vlan4 logical
interface ethernet1 vlan5 logical
interface ethernet1 vlan6 logical
interface ethernet1 vlan7 logical
interface ethernet1 vlan8 logical
interface ethernet1 vlan9 logical
interface ethernet1 vlan10 logical
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif vlan3 intf3 security35
nameif vlan4 intf4 security45
nameif vlan5 intf5 security55
nameif vlan6 intf6 security65
nameif vlan7 intf7 security75
nameif vlan8 intf8 security85
nameif vlan9 intf9 security95
nameif vlan10 intf10 security98
I have to use VLAN trunking to pass the traffic for logical interface above, according to the doc below, the trunking must turn off. So how can I configure Regular cable base failover with VLAN?? Thanks for all helps.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/config/failover.htm#wp1025358
Configuring Switches to Support Failover
Perform the following steps on any Cisco switch ports that connect directly to the PIX Firewall:
Step 1 Enable PortFast.
Step 2 Turn off trunking.
Step 3 Turn off channeling
