02-01-2004 10:13 PM - edited 02-20-2020 11:13 PM
I have two PIX with UR licence. Will I be able to use one as failover if I connect the ethernet interfaces back to back ?
Thanking you in anticipation.
Bipin
02-04-2004 03:35 PM
Hi Bipin,
no you can't do this, you can however send an email to licensing@cisco.com along with the serial number of your pix stating you wish to convert the pix from a ur to an fo, and they will send you a new activation key which will enable this feature. I believe this should not be a chargeable request as an fo pix is cheaper to purchase than a ur. however make sure you keep a copy of your present activation key to avoid you paying for the upgrade if you wish to revert it back to a ur in the future.
hope this helps,
Rowan
02-05-2004 07:16 AM
Another post on this thread already answered this question correctly but I wanted to jump in (for posterity sake) and note that the above post is incorrect. You can indeed use two UR PIX's as a failover pair. An FO license is *not* required. The FO license is offered as a to provide a price break for customers wanting to deploy PIX's in a failover scenerio. Hope this helps clarify.
Scott
02-05-2004 03:20 PM
Scott,
Quite right chap.
I will now beat myself about the head with a wet fish!
Bipin - sorry for the bum information.
02-06-2004 06:16 AM
Nah, make is a wet noodle instead that you beat yourself about the head with. It wasn't that big of a deal ;) Plus, it was probably early in the day when you wrote it.
Scott
02-04-2004 04:00 PM
You can use a serial cable directly between the two or the newer LAN-based failover. Connecting ethernet faces back to back isn't a requirement but that is one way to deploy failover.
UR means unrestricted. All features are licensed including failover. You simply need to configure and enable failover. The output of [show version] should show you "Failover: Enabled". While I've never used Failover with two UR Pixs, I can't think of any reason you will not be able to do this.
