can we use SNMP to monitor both CAS and CAM
We have deployed a full redundant CAS and CAM in our environment. Since this becomes crtical device in our network we would like to monitor the using SNMP. If this is not possible, then how are we to monitor these devices. Please note we are using 4.1(3) software version.
Re: can we use SNMP to monitor both CAS and CAM
Edit the file /perfigo/snmp/snmpd.conf
Add line rocommunity XXX where XXX is your community string.
Then restart the snmpd daemon on the CAS / CAM and you can poll them via snmp version 2c with the community you specified in the snmpd.conf file.
NAC 4.5 and above have better support for mibs and traps.
These tables are defined in the UCD-SNMP-MIB, and can be walked:
prTable - contains a list of processes with a count of how many of each
process must be present
memory - memory currently used
diskTable - disks of the system and how full they are
loadTable - canonical unix load average.
-- prTable OBJECT IDENTIFIER ::= { ucdavis 2 }
-- memory OBJECT IDENTIFIER ::= { ucdavis 4 }
-- diskTable OBJECT IDENTIFIER ::= { ucdavis 9 }
-- loadTable OBJECT IDENTIFIER ::= { ucdavis 10 }
Definition here: http://en.wikipedia.org/wiki/Load_(computing)
The contents of these tables generate DISMAN-EVENT-MIB traps in the
following cases:
DISMAN-EVENT-MIB.txt:mteTriggerFalling is sent when the table being watched
goes from acceptable to unacceptable state.
OBJECT IDENTIFIER 1.3.6.1.2.1.88.2.0.3
DISMAN-EVENT-MIB.txt:mteTriggerRising is sent then the table being watched
goes from unacceptable to acceptable state.
OBJECT IDENTIFIER 1.3.6.1.2.1.88.2.0.2
Parsing the notification will indicate which table generated the
notification.
We send the following two traps:
IF-MIB.txt:linkDown NOTIFICATION-TYPE
OBJECT IDENTIFIER 1.3.6.1.6.3.1.1.5.3
IF-MIB.txt:linkUp NOTIFICATION-TYPE
OBJECT IDENTIFIER 1.3.6.1.6.3.1.1.5.4
Whenever a ethernet interface on the CAM goes up or down, sending linkDown
when the interface goes down and linkUp when it comes back up.
We send the following traps:
SNMPv2-MIB.txt:coldStart NOTIFICATION-TYPE
OBJECT IDENTIFIER 1.3.6.1.6.3.1.1.5.1
NET-SNMP-AGENT-MIB.txt:nsNotifyShutdown NOTIFICATION-TYPE
OBJECT IDENTIFIER 1.3.6.1.4.1.8072.4.0.2
When the SNMP system is started or stopped. The SNMP system is started
whenever the system starts up or the SNMP configuration is changed. The
SNMP system is stopped whenever the system shuts down or the SNMP
configuration is changed. ColdStart is sent when the system starts and a
nsNotifyShutdown is sent when the system stops.
Hi Lucien,
Apprecite your help... but I would like to clarify if this should be done at the CAM side? Also, is there a way for us to directly monitor the CASs?
You can implement this on both and monitor both of them.
You can use an snmp trap receiver that will receive a trap from the CAM / CAS when it does up/down.
You can consider HP Open View for example.
200
