Community Member
Cannot connect to resource using VPN - Strange problem...
I have 1 Windows 2000 PC that is connected behind an 837 which is NAT'ing - users need to access resources on this PC via VPN. The 837 is configured to allow remote clients to VPN in using the Cisco Unity client (Have tried both 3.5 and 3.6 btw). The remote client dials up his local ISP using a standard modem, once connected the client initiates the connection. The client is able to connect without any problems. Once connected you can ping the Windows 2000 PC on the LAN side without any problems, however, if you try and connect to any resources (e.g. NET USE W:\ \\\C$ ) you get an error "Network path cannot be found".
This is where it gets strange - The Windows PC on the LAN side can access any resources on the remote client! (e.g. net use w: \\remote.ip\Sharename will work).
There is no domain or server involved any - just simple pc-to-pc access needed
Both machines are in the same workgroup.
Any ideas? I'm loosing my mind here...
Thanks for any help.
Sho run config below....
Router#sho run
Building configuration...
Current configuration : 2671 bytes
version 12.2
no service pad
hostname Router
no logging buffered
enable secret 5 $1$TuaJ$CJ2./pSfM4uNr88fTal6a/
username xxxxx password xxxxx
username xxx password xxxx
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauth local
aaa session-id common
ip subnet-zero
ip name-server xxx
ip name-server xxx
ip dhcp excluded-address
ip dhcp pool dhcppool
import all
ip audit notify log
ip audit po max-events 100
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group dialin
key cisco123
pool ippool
acl 199
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface Loopback0
ip address
no ip route-cache
no ip mroute-cache
interface Ethernet0
ip address
ip nat inside
no ip route-cache
ip tcp adjust-mss 1452
no ip mroute-cache
hold-queue 100 out
interface ATM0
no ip address
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
dsl power-cutback 0
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer remote-name redback
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname user@domain
ppp chap password 0 password
ppp pap sent-username password xxxxpassword
ppp ipcp dns request
ppp ipcp wins request
hold-queue 224 in
ip local pool ippool
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip route Dialer1
ip http server
access-list 1 permit
access-list 199 permit ip any
access-list 199 deny ip any any
dialer-list 1 protocol ip permit
line con 0
no modem enable
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 120 0
length 0
scheduler max-task-time 5000
Re: Cannot connect to resource using VPN - Strange problem...
Try applying these points,
1. You are using the new version of the cisco vpn client. The release notes indicate that SHA
hashing is no longer supported. You can find the details at the following:
Please change the hashing method to MD5 for the time being in the transform set.
2. The crypto map will need to applied to both the physical and logical interfaces.
