11-07-2007 10:59 PM - edited 02-21-2020 03:22 PM
I have Pix 525 as easy vpn server and pix 501 as hardware vpn client (
nem), I can succesifully establish vpn connection, but i can't browse or ping network on inside interface of pix 525
in atachments you can find my conf
11-08-2007 06:37 AM
The MVDPOOL defined for the VPN Client has a range of 172.18.1.150-172.18.1.200 and I dont see a NAT 0 Statement to by pass NAT. Also, did you want to configure 172.18.110.0/24 has the MVDPOOL, because your configurations are more tailored to allow everything to work when the VPN Clients get an ip address assigned from the 172.18.110.0/24 range.
Let me know how the test goes after making the changes to POOL or NAT 0 command.
Arul
11-09-2007 04:46 AM
Thanks for reply ajaqadee
It's my first time when I'm doing vpn, I didn't understand everything
but I made new configuration, after vpn connection established I can ping from server site pc behind the remote hardware vpn client but from remote site i can't ping inside network of easy vpn server:(
in atachment You can find both configurations
pls write exactly what i have to do, with commands, what to add or what to change
