Capture traffic on Pix 515e vers 7.0
Please help i wish to capture successful traffic on a Pix firewall 515e between two interfaces on the firewall, does anyone know how or what software i can use. Syslog can only monitor unsuccessful traffic
1 REPLY
Re: Capture traffic on Pix 515e vers 7.0
Use the "capture" command on the PIX, see here (http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_70/cref_txt/c.htm#wp1950270) for details. You cna capture traffic coming in one interface (pre-NAT) and capture it again as it goes out the egress interface (post-NAT), tne save it off the PIX in pcap format so you cna look at it with Ethereal.
As an example:
Problem:
User on the Inside with an IP of 192.168.1.8 is having a problem accessing Cisco.com (198.133.219.25). The user is getting NATed to 1.1.1.8
Step 1: Create ACL for both Inside and Outside Interface
access-list 100 permit tcp host 1.1.1.8 host 198.133.219.25 eq 80
access-list 100 permit tcp host 198.133.219.25 eq 80 host 1.1.1.8
access-list 101 permit tcp host 192.168.1.8 host 198.133.219.25 eq 80
access-list 101 permit tcp host 198.133.219.25 eq 80 host 192.168.1.8
Step 2: Create captures on both Inside and Outside Interface
capture out-web access-list 100 buffer 700000 interface outside packet-length 1518
capture in-web access-list 101 buffer 700000 interface inside packet-length 1518
Step 3: Have Inside user access www.cisco.com
Step 4: Copy the captures off to a TFTP server
copy capture:out-web tftp://10.1.1.10 pcap
copy capture:in-web tftp://10.1.1.10 pcap
OR copy using https:
http server enable
http 0.0.0.0 0.0.0.0 outside
https:///capture/out-web/pcap
588
