Capture Traffic - URGENT
I have an Customized Portal application which needs voice/video/authentication traffic to pass from inside natted server to outside...
Opening the required ports didnt help.
If I remove the access-list for inside network it works....
Can someonehelp to give the capture commands .... so that I could capture the traffic and get the required ports....
Or some-other means to get the required ports.....
1 REPLY
Bronze
Re: Capture Traffic - URGENT
use this command
capture capture_name [access-list acl_id][buffer bytes] [ethernet-type type][interface name] [packet-length bytes]
to view
show capture [capture_name] [access-list acl_id] [detail] [dump]
For additional information check this link
http://www.cisco.com/en/US/docs/security/pix/pix62/command/reference/c.html#wpxref65943
Raj
92
