Catalyst 3548 How do I define ports to a vlan
How do I assign ports to a vlan? Can I assign a fastethernet port to more than one vlan? I have already created the new vlan.
Re: Catalyst 3548 How do I define ports to a vlan
The focus of this forum is Security however there are a number of professionals online who may be able to assist you.
We are always considering additional forums for such topics and I will make a note of your post.
If you don't get a suitable response, you may wish to review our resources at the online Technical Assistance Center (www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at www.cisco.com/tac/caseopen
If anyone else in the forum can provide assistance, please reply to this thread.
Thank you for posting.
You can definetly assign the fast ethernet port to more than one VLAN provided it is a trunk port or Q-Port, which is used for forwarding the traffic to diffrent VLANS based on the Tagging.
I believe the URL given in the other reply should provide you with the sufficient information.
hi sknorr,
i think 3548 is a stackable.. IOS based switching solution from cisco.. to assign a port to a vlan.. u have to first go that fastethernet int.. and give following command
int fa0\1
switchport access vlan
to make a port in more than one vlan
int fa0/1
switchport mode multi
switchport vlan multi 1,2
will make fa0/1 in vlans 1 and 2
hope this is helpful to u
my email is shanky@37.com
231
