Catalyst 6509 with FWSM problem
Hi All
A dual Cat6509 core with FWSM blades in slot 8 with failover configuration.
Both switches work perfectly, failover fuctions properly, however approximately once a month the primary switch hangs and as a result there is no connectivity between vlans. To solve the problem I have to restart either the primary or the secondary switch.
show failover displays some errors, I suspect this is causing the problem, can you suggest a solution?
Stateful Failover Logical Update Statistics
Link : failoverstateif Vlan 101
Stateful Obj xmit xerr rcv rerr
General 5284650 20 446597 0
sys cmd 320105 0 319997 24
up time 0 0 0 0
RPC services 8 0 0 0
xlate 0 0 0 0
TCP conn 18718301 0 59123 0
UDP conn 0 0 0 0
ARP tbl 4964509 0 126600 0
RIP Tbl 0 0 0 0
L2BRIDGE Tbl 0 0 0 0
Xlate_Timeout 35 0 0 0
TCP NPs 11795359 0 170947 138173
UDP NPs 15068266 0 103272 138173
Logical Update Queue Information
Cur Max Total
Recv Q: 0 15 446602
Xmit Q: 0 57 5284677
1 REPLY
Re: Catalyst 6509 with FWSM problem
90
