03-12-2003 02:03 AM - edited 03-09-2019 02:28 AM
hallo
I have a cisco 1721 router to make LAN-to-LAN and Internet access.
The WAN link is FR with two PVC one for LAN-to-LAN and one for Internet.
On LAN-to-LAN PVC we need to implement VoIP so I would use LLQ, other QoS features and CEF (Cisco Express Forwarding).
On Internet PVC we would have IOS Firewall with CBAC.
Can we use CBAC and CEF at same time ?
Solved! Go to Solution.
03-12-2003 08:26 PM
Not only should you use CEF, but you must. LLQ as implemented with CBWFQ requires that the router have CEF enalbed. CEF will not affect the funtionality of CBAC. CEF is merely a switching-method analagous to fast-switching, except that is has the information pre-stored in a table for quick access. It is the most efficient switching method your router can use.
03-12-2003 03:43 PM
Sure, shouldn't be an issue. Are you seeing problems with it?
03-13-2003 11:58 PM
My question was to clear some doubts.
Thankyou for help me
best regards
03-12-2003 08:26 PM
