CBAC Config on 2610 running IOS 12.2(2)T
Hi all! Trying to configure CBAC on 2610 running IOS ver.12.2(2)T. My Cisco reseller insists my platform supports the Cisco IOS Firewall Feature set. However, whenever I issue the command ''show ip inspect all'' to verify the CBAC capability, the output shows that the CBAC is not supported (% Invalid input detected at '^' marker)! Any comment/help will be appreciated!
Thanks.
Joe P.
Re: CBAC Config on 2610 running IOS 12.2(2)T
Hi Joe,
What we need to do is check the actualy image you are running with a "sh version" off the router.
You should have this image:
"c2600-io3-mz.122-2.T.bin".
Please post us the image name and we can take it from there.
R/Catherine
Dear Catherine,
The most relevant info from the 'sh ver ' output is as follows:
*system image file is 'flash:c2600-i-mz.122-2.T.bin'*IOS (tm) C2600 Software (C2600-I-M), Version 12.2(2)T, RELEASE SOFTWARE (fc1).
Should you need any other detail, kindly let me know.
Regards.
Joe P.
100
