CEP enrollment process on PIX 515 running 6.3
payatola1
Does anyone have any documentation on the process of CEP enrollment for a PIX 515? Is it true that the Root CA can also be enrolled via CEP as well as the Device Certificate itself?
Payum
gfullage
This should help http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_62/config/ipsecint.htm#38608
The PIX uses SCEP to get all the certificates so just follow the standard procedure, making sure your CA supports SCEP enrollment.
